#11 |
Liked 57 Times in 24 Posts
I would think a brake lite switch would trigger
at a low pressure Ours is set at 700 psi David |
#12 |
Liked 682 Times in 203 Posts
Anyone come up with a part number. McMaster Carr has a switch 3427K5, but it is the Buna rubber.
#13 |
Liked 21 Times in 13 Posts
I use one from transducers direst p/n TDPS8. adjustable, 250-1000 psi, 1/8 pipe thread. It works perfect, but looking at the data sheet, it has a buna N diaphram. Contact them and ask for something similar with viton.
513-583-9491 SALES@TRANSDUCERSDIRECT.COM
Brian Carpenter Stock 1358 |
#14 |
Liked 453 Times in 146 Posts
Call Folk Race Cars. They sell what's called the Ultimate Brake Pressure Switch. Easy to adjust to different brake PSI requirements. Two wires.
( Has three but the black wire is not used). 150.00?. Steve Teeter Stk/SS 620 |
#15 |
Liked 75 Times in 28 Posts
What brake fluid are you using with these switches?
Thanks, Mike |
#16 |
Liked 133 Times in 76 Posts
I'll have to dig up the part # but I just use a 2 wire brake pressure switch that has pipe threads. Listing is probably for and old Ford car.
Just found my spare switch, it's an S194 from Carquest. Last edited by Eman; 08-07-2023 at 11:16 AM. |
