Old 09-06-2023, 01:21 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Anti-Roll Bar
Running 1995 Caprice in J/SA
Launches hard with left front coming off ground.
Right side barely stays on ground.
Want to stop the twisting.
Are Anti Roll Bars Legal in Stock?
Current solution using Double Adjustable Shocks.
Using Dick Miller components including Suspension Brace.
It wants to launch harder.
Too high a Launch rpm breaks tires loose.
Dan
Old 09-06-2023, 01:25 PM   #2
Billy Nees
Default Re: Anti-Roll Bar
Are Anti Roll Bars Legal in Stock? Dan
Yes but legally they can't be welded to the frame. They must be bolted.
Billy Nees 1188 STK, SS
Old 09-06-2023, 02:32 PM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
Billy is correct, must be bolt-on only. I like the H&R Parts 'n' Stuff bar. It may be difficult to find one for a GM "B" body.
Jim Kaekel 3836 STK
Old 09-06-2023, 04:39 PM   #4
Jeff Stout
Liked 706 Times in 283 Posts
Right rear air bag? Just thinking out loud.
Old 09-06-2023, 05:15 PM   #5
GUMP
Liked 2,359 Times in 557 Posts
A stiffer passenger side rear spring will help some.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 09-06-2023, 09:49 PM   #6
Dan Fahey
Dan Fahey's Avatar
Has SS Roll bar and Airbags.
Stiffer Roll Bars are available and bolt on.
Double Adjustable Shocks are next.
Old 09-07-2023, 01:02 AM   #7
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Dan… Like previously mentioned add some spring to the RH Side. Try a "Cargo Coil" (Lesjofors 4412114) or a Wagon Spring (Dorman 566208). Could be a simple low cost fix. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 09-07-2023, 01:40 AM   #8
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
bolt in ladder bar/torque bar, drivers side. LONNNNNNNG
Damn. Not sure where my head was. Passenger side. Mark has a point. No longer than OEM BUT (a little hint) it can be tied into Roll bar.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 09-07-2023, 05:50 AM   #9
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Anti-Roll Bar
Good morning Dan and to all,
I was going to suggest a quality set of shocks, they aren't going to be cheap but I'm sure will be worth it allowing you the ability to "tune " your suspension. Another thing that comes to mind is to make sure all your suspension components are "free to move" and the front and rear wheels are all heading in the same direction. I believe if you allow the suspension to work / move that you should be able to leave at a higher RPM, and pick up some ET, and not spin the tires. Years ago I bracket raced a 1962 Impala with a coil suspension, and I found found once I freed up the suspension and allowed free movement, I was able to leave around 4500 rpm. The car had 9x30 firestone slicks and a 350 chevy engine. Nothing fancy by todays standards. I hope this helps , if you have any questions I'll be a the Grove for the Dutch Classic. Good luck.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 09-07-2023, 01:29 PM   #10
Not legal. Lower pivot point can't be any further forward than OEM.
