Old 09-24-2023, 10:36 PM   #61
Default Re: U/SA
https://www.dragracecentral.com/DRCS...r2004#indextop
Okay then. I'm confused...
Wasn't there a second shootout, when Bob Shaw ran his Seville? He ran in the 12's but didn't end up winning, because it was a CIC race?
Maybe I'm thinking of Beard's deal at Columbus
Old 09-24-2023, 11:41 PM   #62
Jack McCarthy
Liked 511 Times in 122 Posts
Default Re: U/SA
after the first year pat ran a FREE no breakout race on friday night. first year shaw won with the TAXI freemans car i made semis in witch doctor fast guys whined so after that he made it a CIC race from then on ... bob went -217 in caddy in final but took a hit ever round to get there and lost
that clear it up ??
capt
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 09-25-2023, 01:36 AM   #63
Tom P
Liked 239 Times in 94 Posts
Default Re: U/SA
Originally Posted by goinbroke2 View Post
I've always wanted to build a stocker, no way can I afford it, so I'll buy....I'm a ford guy so I can buy a "CJ for $125,000" or a "351C for $70,000" or once in a while, far, far away (in the states, lol) I'll see a pinto/escort/foxbody. There are your ford choices if you want to run a ford in Stock.
How about a mid 70's Torino 460... red with a white Starsky and Hutch stripe and slot mags would be cool.
Wouldn't fit U unless they switched it's weight as much as new Challengers but the other way.
Old 09-25-2023, 09:02 AM   #64
Billy Nees
Default Re: U/SA
Perhaps if a combo hasn't been built or run for X amount of time, hp should be reverted to stock hp? Kind of like records?
I've always thought that this would be a good idea especially if a combo has NEVER been competitively run in competition. But maybe not go all of the way back to OEM HP in most cases. There would have to be some common sense involved. Also, if a combo has EVER received a HP hit IN COMPETITION, it wouldn't qualify.
Billy Nees 1188 STK, SS
Old 09-25-2023, 12:25 PM   #65
Default Re: U/SA
that clear it up ??
capt
Okay...Sort of.
So if it happens again, do we want a CIC deal? 1 second under trigger?
Next year @ St Louis would be centrally located at least...Maybe Tyler and co. would accommodate it. With all the racing available, it might be worth it to travel from the outer reaches.
Thoughts , anyone ?
Old 09-26-2023, 05:06 PM   #66
L.Fite
Liked 498 Times in 244 Posts
Default Re: U/SA
So...
How is the 230/140hp L6 as a combo?
In a Camaro.
Looks tough... no compression, 1bbl...
How's parts availability?
Curiosity strikes...
L.Fite is offline   Reply With Quote
Old 09-26-2023, 06:24 PM   #67
Doug Hoven
Liked 869 Times in 165 Posts
Default Re: U/SA
Originally Posted by L.Fite View Post
So...
In a Camaro.
Billy would know better than I would, being that he played with two different cars with that combo for about 20 years. Some parts are easier to find than others. When I ordered a cam 2 years ago, I was told by bullet they had to search far and wide for a cam core for me. Stock connecting rods and crankshaft seems fine for the rpm capability of the motor (lack there of). The intakes and cylinder heads don't exactly fall out of trees, but they are out there. When I rebuilt the engine, it was not a "high dollar" rebuild, but it was all good parts. It's not a bad U/SA car to bracket race, but is more competitive in V/SA. I wouldn't be surprised with enough cash and time it could be a .75-.80 under combo in V. Would be neat to see one built with a third pedal. I was close to doing that, but went the v8 route instead. BTW for those curious, I had a vacuum gauge on the car for a few runs. Pulled about 7-8 in. of vacuum at the top end with that tiny carb. Fun fact the dimensions are the same as one hole of an 850 holley.
1189 F/SA
Defunzalo Racing Enterprises
Old 09-26-2023, 08:03 PM   #68
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: U/SA
Afew years back I ran a 82 Monte Carlo in U with a 267/ It was factory rated at 115 hp, but Nhra saw fit to bump hp to150 without even seeing what could be done with it.Stated out with15.0 and eventually got it to run fairly consistent 14.40's and 50's. Best I ever ran was 14.20 @90 in killer air at No Problem. This was not a money is no object car but had good parts in car and engine.I felt that hp on engine was too high and that it should have been around 135 or 140 at start , then s ee how it turns out.Sure enjoyed running car and if things played out right would like to run it again but there's no way I feel like it's a 1.30 or higher car.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 09-27-2023, 08:55 AM   #69
Billy Nees
Default Re: U/SA
So...How is the 230/140hp L6 as a combo?
It treated me quite well. It would need more HP back to make it a "hitter" in the 21ST Century but it is a good, dependable combo that would probably respond well to a metric or a 4 speed. You can have cams made that will "make" compression (cylinder pressure) but, in the end you're still dealing with a 210 CFM carb..
Old 09-27-2023, 10:17 AM   #70
GTS340
Liked 1,360 Times in 415 Posts
Default Re: U/SA
Gees 210 is a little guy. I like your line Billy. Might have to call you General Nees. Fun stuff this U/SA class. How is the average doing on the 302 this year?
Paul Haszlauer
