#11 |
Liked 134 Times in 32 Posts
Just put in a dispute with your credit card company. They will reverse the charge and credit your account.
#12 |
Liked 449 Times in 98 Posts
Well its gonna be hard to comply with the new flex plate shield rule for many of us with stock transmission tunnels, no SFI transmission case option and no CSR shield. Hate to say it, but were gonna need removable tunnels in Stock to comply with the new rule given lack of product availability.
#13 |
Liked 805 Times in 341 Posts
I sure wish someone else would start to manufacture the carbon fiber shields!
#14 | |
Liked 55 Times in 26 Posts
What is the new rule?? I knew they were requiring sfi flexplate.. but didnt know about the shield.. all automatic cars?
#15 | |
Liked 759 Times in 379 Posts
General Regulations Section 21, page 17 2:14 TRANSMISSION, AUTOMATIC/NHRAACCEPTED All cars running 10.99 (*6.99) seconds and quicker must have an NHRA-accepted locking-type dipstick on the transmission, and dipstick/filler tubes must be securely fastened (i.e., bolted, aircraft clamped). Wire ties, hose clamps, etc. prohibited. Any non-OEM automatic floor-mounted automatic transmission shifter must be equipped with a spring-loaded positive reverse lockout device to prevent the shifter from accidentally being put into reverse gear. Functional neutral safety switch mandatory. All transmission lines must be metallic or highpressure-type hose. All vehicles running quicker than 10.99 seconds (*6.99) or faster than 135 mph (except some Stock and Super Stock classes as noted under Class Requirements) and using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and labeled accordingly. (“Blanket”-type shield, appropriately labeled as meeting SFI Spec 4.1, permitted.) All non-blanket-type shields must incorporate two (or one, per manufacturer’s instructions) 3/4 x 1/8-inch straps that bolt to the shield on each side and pass under the transmission pan, or transmission pan must be labeled as meeting SFI Spec 4.1. Permitted in all classes where an automatic transmission is used. Comp, Super Comp, Super Gas, 9.99 or quicker E.T. cars, and 135-mph or faster E.T. cars using an automatic transmission, Lenco Drive, or BRT must be equipped with a flexplate meeting SFI Spec 29.1 and covered by a flexplate shield meeting SFI Spec 30.1. Transmission that can utilize a high-gear transbrake must be supported by the use of two momentary buttons (one to arm the system, second as the main transbrake). Air shifter bottles must be stamped with DOT-1800 pound rating (minimum) and be securely mounted (i.e., no tie wraps or hose clamps). Last edited by 1320racer; 09-26-2023 at 11:39 AM. |
#16 |
Stock/Super Stock - Beginning January 1, 2024, SFI Flexplate mandatory on all V8 vehicles.
#17 |
long overdue. too many old guys still running 50 year old flexplates and others chinese junk.
#18 |
The 50 year old flexplates aren't the problem and neither is the good stuff (ATI, Meziere). It's the Chinese stuff.
#19 |
My mistake, I confused the new SFI flex plate rule with the old 9.99 flex plate shield rule. Since I am moving to A/SA, their both new rules for me to comply with.
#20 | |
Ok, i knew about this.. I just thought it had gotten changed for the slower class cars as well..Doesnt effect me lol
