Liked 231 Times in 107 Posts
Has anyone converted Shubeck Hyd over to solids?
Liked 172 Times in 81 Posts
Mine are converting themselves, 3 have the plungers stuck in the bottom position. Other than that, they still look like new after 12 seasons.
I would think with the new solid lifters allowed rule a better ceramic lifter could be built as they wouldn't have to allow room for the plunger, just a thought.
Jim Mantle U/V/SA 6632 |
#3 | |
Liked 1,104 Times in 302 Posts
So,..if you are set on being able to run roller lifters in a Stocker, there are almost 30 years worth of engine combinations in the NHRA Classification Guide that came from the factory WITH roller lifters, for you to choose from.
Gotta ask yourself WHY did OEM decide to go to rollers if flats are cheaper to make?
#6 | |
Liked 497 Times in 243 Posts
But there is supposed to be remedies for that... (additives)... So... that begs the question, what is the REAL REASON for the failures? Self inflicted... (spring pressure)...? Crappy material/ QC...? Or some yet unknown quantity... Inquiring minds would like to know... |
#7 | |
Hmmm, almost makes you want to built a later model car to enjoy all those benefits, isn`t it!
NHRA 6390 STK M/S 85 Mustang Last edited by Rory McNeil; 10-24-2023 at 10:12 PM. |
Liked 49 Times in 22 Posts
Cummings went to roller lifters in the last few years, and they have had a lot of problems with lifter failure, and i heard its because of the oil, to get away from the high zinc oil.
Steven Barnes Stock 704 N/SA |
Liked 529 Times in 36 Posts
I have used Renegade race oil 5/20 and 10/30 it only comes in semi-synthetic, I have used it for over 10 years with great results.
Darcy Clarke 6254 A/SA SS/EA |
I have been running Brad Penn/ Penngrade 1 high ZDDP oils on both my flat tappet, and hydraulic roller stuff, for many years, never had an issue. This oil is advertised as "the flat tappet oil" right on the bottle, and I have never felt the need to try to be a backyard chemist by trying to add any other "magic elixir " to it.
