Liked 2,742 Times in 968 Posts
What is the desired temperature for both Water and Oil for maximum performance? Also how many racers are using an Oil temperature gauge?
Liked 90 Times in 52 Posts
Frank ... you should of asked how any use a oil pan heater to maintain oil pan temp thuout the days racin
Liked 974 Times in 310 Posts
Hot and cold........... I think you can figure out which one likes what. And yes on temp gauge
Liked 1,604 Times in 583 Posts
There are many variables as regards to the weight of the oil in use, and synthetic vs Dinosaur oil. Synthetics have a higher tolerance to heat.
Also, the block material has to be taken into consideration. The material expansion between a cast iron block and an aluminum block is different also and it will affect the piston ring sealing. Based on what I have observed in the dyno and discussions with others, the general temperature guidelines at the staging lanes are as follows: Water 110° ~ 120° Oil: 170° ~ 180° |
I was told by a very wise man a long time ago, "Billy you want the top of the engine freezing and the bottom melting!".
Liked 4 Times in 1 Post
0W10 100% Ester base oil will perform well and won’t have to be very warm at all to it. Just my opinion.
Liked 10,830 Times in 2,251 Posts
An Arkansas definition from some FE Ford folks. “ You want the top turd cold and the oil like turpentine.”
Liked 783 Times in 195 Posts
Arkansas??
#9 | |
Liked 133 Times in 76 Posts
