Liked 1,365 Times in 368 Posts
Got mine for my build in the mail a few weeks ago. Y'all have preferences? I just got the el-cheapo sfi certified one from Jegs given I'm not trying to rotate the Earth. I've had no issues on my .90 stuff with them too but some people swear by particular brands.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 2,024 Times in 607 Posts
I have used the Summit and Pioneer ones and haven’t had a problem. One had some chipping on the teeth after several years. Still worked when I removed it. This go around I bought one from ATI. The quality is much better. Thicker steel and the ring gear is Tig welded at closer intervals.
Mike Pearson 2485 SS |
Liked 53 Times in 17 Posts
New ATI for the Camaro. Can't find a shield for a T350 (None in stock).
#4 | |
Ken Kier makes blanket that is supposed fit real good. I was thinking about that too. Went with the aluminum shield.
TCI says they don't know when they will be able to send one! May have to look at a blanket.
Liked 90 Times in 52 Posts
so just to understand rule there is no expiry on existing SFI flexplates & if you are using a aftermarket transmission case such as Reid , ATI etc you still need shield or blanket ?
Liked 1,471 Times in 308 Posts
Pete, I hope not, and I don't think you need either if your "Super Case"
comes with 2 SFI #'s. One for the regular shield or blanket area & one for the Flexplate Shield. I just bought an ATI unit to get rid of the aggravation of having to worry about them, and taking them on & off. J.R. |
I checked the Reid transmission site & their aftermarket powerglide case does Not need a Shield as it has a SFI rating of 4.1 & does Not need a Flexplate shield as has a SFI rating of 30.1 .. just need the answer on expiry dates of existing SFI flexplates
