Old 01-25-2024, 06:21 PM   #31
Doug Hoven
Liked 867 Times in 165 Posts
Default Re: Ways to check on the use of illegal devices
The ARC module is already spelled out as being prohibited in Sportsman categories. I can’t imagine any sort of “traction control” being very consistent. Killing power, especially if trying to replicate a curve, may be too “stop and go” for it to work well in a bracket racing scenario.
1189 F/SA
Defunzalo Racing Enterprises
Old 01-25-2024, 06:48 PM   #32
DG
DG's Avatar
Liked 468 Times in 99 Posts
I have been around long enough to remember the old adage "your not cheating if you don't get caught". We all know its self certification on entries and cars rarely get looked at closely anymore. That said, I think the vast majority of racers do not intentionally cheat.
DG is offline   Reply With Quote
Old 01-25-2024, 07:17 PM   #33
Bill Grubbs
Liked 564 Times in 66 Posts
Originally Posted by Don Kennedy View Post
The thought occured to me that just maybe there are many ways to check on racers who are using illegal devises to have a advantge of other racers I will start first have a camera Zoom into the drivers compartment showing the tree plus the driver to see when the release the button ,any other suggestions ??
The absolute best way to catch someone who is cheating is to put up the money for an inspection. Of course you should provide tech with as detailed information as you can. I believe a visual inspection is in the neighborhood of $200-$300.
Put up, or…
Bill Grubbs is offline   Reply With Quote
Old 01-25-2024, 08:12 PM   #34
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
you are very wrong
Old 01-26-2024, 09:20 AM   #35
Doug Hoven
Originally Posted by 1320racer View Post
you are very wrong
I see the flaw in my statement. I guess it really depends what is really defined as "traction control." I would put it into 2 categories, active, and passive traction control. I would consider time based timing retards to be passive. They are either programmed into the msd box, or the ecu. With these, the timing curve will be exactly the same every run, which has proven to be very consistent for many cars that use a setup like this. What I can't imagine to be super consistent would be a type of "active" traction control, where the msd or ecu is responding to wheel speed. I know that computers have come a long way, but the response time of something like this may not be quite fast enough for it to work with absolute accuracy. Correct me if I'm wrong, and I'm sure you will, but I've never heard of someone using an arc module or something similar that does the work of a "matty box" for you, and replicates runs with accuracy by changing the tune of the car going down the track.
1189 F/SA
Old 01-26-2024, 09:40 AM   #36
Frank Castros
Liked 2,745 Times in 969 Posts
Remember when it was about cutting a good light and running your dial? The only external wiring was for the Line Lock.
Old 01-26-2024, 09:45 AM   #37
Billy Nees
It COULD be that way again but I won't hold my breath waiting.
Billy Nees 1188 STK, SS
Old 01-26-2024, 10:09 AM   #38
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Originally Posted by DG View Post
I had not heard of the ARC referenced above so I looked it up. For those that don't know what the MSD ARC linked with the Grid can do, this is from MSD's website:
"OVERVIEW
Now there is even more control with the PN 7761 module for the Power Grid System Controller. This module sets rpm limits based on slew rate (rpm acceleration) or based on time since launch. All of this is programmed seamlessly in MSD View.
The ARC module stands for Advanced RPM Control, it basically allows your race car to remain consistent, pass after pass, controlling your engines rpm curve during a pass. This helps you get down the track quicker and far more consistent. By using the MSD View software we can control the rpm down to a hundredth of a second and control the driveshaft speed for maximum traction. We can also pull out timing for a split second should we encounter tire slip. Set 3 different timing Retard curves and a Rev Limit Curve to control wheelspin."
Nice video explaining the system here:
Basically, it appears you set the driveshaft rpm curve in the Grid for a given ET, dial in and like magic you run within a hundreth of your dial in.
Dont feel bad. I had to look that up too. I had no idea what the ARC module did. I
guess I am old school. If I cant win without electronics or cheating then I dont get to. My deal is to cut a light and run the dial. I work real hard to do that. I am not a "hitter" but I do go some rounds and have finshed top 10 in the division 2 out of the past 4 seasons. I also had a divisional win in 22. Personally I dont think there is many out there cheating.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-26-2024, 10:41 AM   #39
1320racer
1320racer's Avatar
Doug, you're not going to hear of anyone using an ARC module in class or bracket racing because it is illegal.
That said, I have no first hand knowledge of the matty box and neither does anyone else that isn't/hasn't used it and they ain't talking about it no mind doing so on a forum but I am well aware of what can be done with the ARC module and if the question is can it be used for to make your car deadly consistent? That answer is YES and by deadly, I'm not talking hundreds, I telling you thousands from pass to pass but again, the best of the best bracket cars do this also without an ARC module.
start at 8:54
Old 01-26-2024, 11:17 AM   #40
Frank Castros
Someone is buying this module. I wonder how many MSD sells for $800.00?
