Liked 90 Times in 52 Posts
late 90.s GM Bow Tie Sportsman sbc block question .. engine still in car how do I tell if it is a 1 or 2 piece rear seal .. i see the aluminum seal plate behind the crank flange in photos of BowTie blocks in GM catalog but no other data telling me if a 1 or 2 piece without disassembly .. has typical 6 bolt crank flange .. thanks
Liked 1,937 Times in 582 Posts
They do come both ways.
Mike Pearson 2485 SS |
Yes Mike I know both blocks come both ways .. thats my question how do I identify with out disasembly without pan off .. is the aluminum seal plate blocking a way of knowing 1 or 2 piece without teardown ?
If it has the aluminum seal plate then it is a one piece seal block. The two piece does not use that aluminum plate. You can run a 2 piece crankshaft in the one piece blocks with the adapter. The work fine.
Mike .. so how come on the GM perf parts site both photos of sportman blocks have aluminum seal plates for 1 & 2 piece
so mike how come on the GM perf parts website they show photos of both BowTie block part # .s of 1 & 2 piece with aluminum seal plates
If it’s a one piece seal they still have a plate. The two piece adapter bolts to the same flange and has the groove for the two piece seal. That way you can run a 2 piece crankshaft or the one piece crank in those blocks. I have one bow tie block that is for a two piece seal only and it does not have a plate. It has a standard rear main cap. You can only use a two piece seal crank in that block.
Mike Pearson 2485 SS Last edited by Mike Pearson; 02-01-2024 at 08:38 PM. |
Liked 497 Times in 243 Posts
can you see the flange on the crank?
yes can see flange ..its scalloped around one side of 3 bolts & regular curved edge along where dowel pin would go
Liked 133 Times in 76 Posts
If it has a flange a one piece seal can't slide over it.
