Liked 90 Times in 52 Posts
yes can see flange ..its scalloped around one side of 3 bolts & regular curved edge along where dowel pin would go
Liked 133 Times in 76 Posts
If it has a flange a one piece seal can't slide over it.
Liked 507 Times in 249 Posts
Two piece...
L.Fite .. now confused that you think its a 2 piece where as Mike P thinks its a 1 piece .. so a 1 or 2 piece would have different hole dia on the rear flange if one was ordering a new flywheel or flexplate ?
#5 | |
Liked 398 Times in 153 Posts
Yes, two piece and one piece flexplates are different. Yours must be a two piece (as Eman said) a one piece can NOT have a flange on it.
Phil Molski PMR Performance S/C 1623 |
so there must be two hole diameters to locate the center to mount the 6 bolts
Yes, that is correct.
Liked 2,013 Times in 604 Posts
In the original post the question was whether the block was 1 or 2 piece. That is how I answered the question. He did not ask about the crank. If the crank has a flange like the older style then it is a 2 piece seal and will take the older style flex plate.
Mike Pearson 2485 SS |
Banned
Liked 179 Times in 89 Posts
It was my belief that there's only one type of Bow Tie small block and you use the seal adapter to match your crank.
thanks guys for all the comments
