Old 02-19-2024, 12:56 PM   #13
JP1738
JP1738's Avatar
Liked 1,226 Times in 343 Posts
Default Re: Crap, th350 emergency
D, If your T350 doesn't have a 2.75 low, I wouldn't put too much more into it.
Your car needs a T 200, but at least you know you can run under the index with what you've got. If you decide to patch it up, it shouldn't cost too much, at that hp level.
It is quite possible that the converter is full of trash by now, so you'll want to figure that into the equation too.
Very true, I've had another user reach out with the same sentiment. I'll flush it out and see if it's packed with crud. Might have to send it off and gone through. Probably try to loosen it a touch while I'm at it. Any good recommendations that could get a converter turned around pretty quick in the NC/SC area? If possible, I'd like to throw the new trans in and test again this weekend to make sure the new trans is good to go. If I can find a local place, I'll just drive it there so I don't have to wait on or risk shipping.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
