Old 02-20-2024, 02:35 PM   #1
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Default Re: Crap, th350 emergency
Originally Posted by JP1738 View Post
Any good recommendations that could get a converter turned around pretty quick in the NC/SC area? If possible,
All my converters are done at Atlantic Coast Converter in Conway South Carolina. This is a drag racing family that knows what customer service is.
https://www.facebook.com/atlanticcoast.converters.3/
Ray
Dave Swimm is a former SS Pontiac racer. He always raced Pontiac.
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 02-20-2024, 03:02 PM   #2
JP1738
JP1738's Avatar
Liked 1,226 Times in 343 Posts
Here's some aftermath images for you guys.
Converter fluid looks brand new. It appears the filter kept most, if not all of the clutch material out of it.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 02-20-2024, 05:36 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
so what's the plan to be ready for Gainesville?
Old 02-21-2024, 11:16 AM   #4
JP1738
JP1738's Avatar
I don't really know yet. I've got a brand new transmission sitting in the floor of the shop ready to go in, but everyone on here seems to be really stressing the potential debris in the converter and I'm afraid to put it all back together without cutting my converter open and cleaning it. At this point I can't find any evidence that there is any debris in the converter after flushing and draining it over the course of this week. The fluid looked new the first time I drained it and has not revealed any additional debris since I started pouring fluid in it to flush it out. I also have not torn into my transmission to see what came apart or failed, so I don't know what the material is from or if it could have made it's way into the converter.
Dawson Pauley
Old 02-21-2024, 11:51 AM   #5
Mark Ugrich
Liked 71 Times in 38 Posts
It’s always difficult to determine what’s inside a converter after something fails.If there is absolutely no sign of metal or clutch material you may be ok.The correct thing to do is cut it apart and check.The fluid path in a 350 starts by going through the filter, into the pump and then to the converter.
Then to the valve body and the rest of the transmission.Maybe your trans guy can help advise if it’s worth taking a chance.
Old 02-21-2024, 12:28 PM   #6
Yes , when racers tell you you should have the converter cut open and cleaned and inspected , they are certainly correct.
However, you can take a chance,by not doing so, in your situation.
Most of the long term fine debris in a converter, ends up around the overlap, where the weld seam is, due to centrifugal force . That's probably not going anywhere.
It there's anything recent in there, it's possible to flush it up.
First thing you should do is set it on the bench and place a clear plastic tube all the way in and down to the pilot area. Siphon the remaining ATF out over the edge of the bench.
Then, if you have a parts cleaner, with fresh, clean solvent in it, place the tube all the way in and let it run for a while.
If you don't have that available, then pick up a gallon of mineral spirits and pour in as much as you can. Place a T350 input shaft in the unit and spin the turbine back and forth to stir up the fluid. Then quickly dump what you can into a clean pan. Finish by siphoning out the remainder of the solvent.
Then blow it out thoroughly , best you can .
If you haven't found a big chunks by now, you'll probably be okay, assuming the bearings and thrust washers aren't falling apart.
Disclaimer...You heard this from my ghost writer. Not from me.
Old 02-21-2024, 01:58 PM   #7
JP1738
JP1738's Avatar
Thank you Mark Yacavone's ghost writer, I will do this tonight before reinstalling my transmission and converter.
Dawson Pauley
Old 02-21-2024, 12:13 PM   #8
1320racer
1320racer's Avatar
Dawson, based on your bolded comments above, I'd reinstall it and go race. Then change the fluid again after Gainesville. I've done the same numerous times over 3 decades without issue. I'm not a believer of cutting open converters to clean or "freshen". My converters only go back to the manufacturer if broken. Put a magnet in the pan if you already don't have one in there.
Who's converter are you running and what does it flash to and fall back to on the shift?
Old 02-21-2024, 12:45 PM   #9
JP1738
JP1738's Avatar
I had not considered running it and then changing the fluid, that's a fabulous idea and would help give me piece of mind. I don't know the converter brand, but I'll post a picture of what was stamped on the top and bottom of it so maybe someone will recognize it. The pan has a magnet, I'll make sure to clean it well and put it back when it goes back together. It's really hard to tell what the converter clashes to. The brakes aren't good enough to flash it in the pits, and first gear is so short I'm not sure what it goes to right off the line as the rpms climb so quickly. Looking back at in-car camera footage, it appears to flash around 4600 and fall to 5000-5100 on both gear changes. That was with the original intake that was on the car though, I don't have data on the new one yet, and it definitely made more power with it.
Dawson Pauley
Old 02-21-2024, 01:09 PM   #10
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Easy way to flash convertor. After a run on return road stop car and put in high. Floor throttle and watch tach for highest reading.
