Old 03-12-2024, 09:38 PM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default Re: Beware of Summit Branded braided hose!!!
If you want a great braided hose designed for motorsports, that will not collapse, that is compatible with all fuels, retains, and does not permeate or leak fuel vapors, I recommend the Goodridge G-Line XF 811 hose. Due to having a full length Teflon liner, therefore, it requires the use of Goodridge fittings also.
Another option is using general aviation steel braided hoses that meet the requirements of MIL-H-83797 or FAA-TSO C53a, Type A such as Aeroquip 601/AE701 hose and it is compatible with AN and MS fittings. A good source for the Aeroquip hose are stores like Aircraft Spruce.
Both of these hoses do not have a shelf life. There are some MIL-SPEC and SAE spec hoses that have a limited life of 10 years.
This hose and fittings look much better for a race car application than the industrial products I am familiar with.
Thanks for the info!
Jim Hawkins is offline   Reply With Quote
