Old 03-13-2024, 02:18 PM   #1
prostockpete1
Liked 90 Times in 52 Posts
Default flex plate expiry date tech inspection
After a few points meets & one national event of the new year has the nhra tech team been crawling under automatic equipped cars checking for sfi flex plate expiry dates or asking the driver on their honor is the flex plate up to date or are racers taking photo of of the sfi tag to show tech
prostockpete1 is offline   Reply With Quote
Old 03-13-2024, 04:22 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Default Re: flex plate expiry date tech inspection
I have not heard of anyone being checked or asked. I do have pictures of all my SFI tags in my phone
Mike Pearson 2485 SS
Old 03-13-2024, 05:48 PM   #3
jmcarter
jmcarter's Avatar
I do it like Mike and take pictures. It would be holy PITA for them to even get a clear view of the flexplate tag on mine (904 trans). I had a few choice words for their new rule when I was wrestling the trans out and back in. Someone needs to convince them a Mopar flexplate is a different animal.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-14-2024, 03:16 PM   #4
james schaechter
Liked 1,436 Times in 299 Posts
I could see them requiring manufacturers to supply racers a sheet with matching sfi stickers like they do for clutches. Then if you just show them the current sfi sticker sheet . They ask for that frequently on clutch cars. Pretty easy as long as you are current.
James Schaechter 3163 STK
Old 03-14-2024, 10:23 PM   #5
I don't know about this one, Jim.
There are SFI flex plates on Ebay or Amazon for under a hundred bucks. Are they real or bogus? I don't know, but getting registration papers to go along with them , either way, might be a real trick.
On the other hand, there are what, two or three high tech drag racing clutch guys out there? Of course they are in the thousands of dollar range, and I'm sure they're worth it.
I don't see where it would be a big deal for them to provide SFI paperwork.
Back to autos... I don't think we need to give them any more ideas here ;-)
Old 03-15-2024, 09:43 AM   #6
63corvette
Liked 359 Times in 103 Posts
Reid has stopped installing the SFI stickers on the transmission cases in for recertification. They stamp the case with the numbers for the case and flex plate shield on the side of the case flange and include the stickers matching the case for the customer to use for tech purposes.
I carry my stickers in the trailer where I hope I can find them if asked to provide them.
Just my experience.
Rick Cates
Canyon, TX
63corvette is offline   Reply With Quote
Old 03-16-2024, 01:07 PM   #7
Steve Grady
Steve Grady's Avatar
Liked 128 Times in 43 Posts
When you have the case where you can photograph it and the SFI sticker card with your phone you can show tech the photos with the matching numbers. May be easier to keep track of while keeping the card with the stickers where it won't get lost.
Reid cases also have a Mfg Date and Serial number that is stamped on case and on the card the SFI stickers are on.
Just my experience.
Rick Cates
Canyon, TX
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 03-21-2024, 04:33 PM   #8
63corvette
Directly from an un-named NHRA employee there is no plan to do inspections for sfi tag dates at the races unless there is found to be a reason or a need to do so on the flex plates.
The racer signs the tech card certification saying it is good and unless there is some reason to question that you are good.
It all falls back on the racer.
I feel sure there will continue to be staging lane spot checks for the easy and quick things to check.
Rick Cates
Canyon, TX
Old 03-21-2024, 06:13 PM   #9
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
A lot easier to just check all the broken pieces laying on track after it comes a part.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-28-2024, 12:02 PM   #10
John Dinkel
Liked 263 Times in 68 Posts
Angry Re: flex plate expiry date tech inspection
I removed my Mopar SFI flex plate 29.1 dated Dec 2002 and it looks like new. Sure seems like a lot of money to spend when they last so long.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
