Looking for a set of 876x2.250x.090 wall.need the oversized pins as the pin bores are a bit worn. Have tried Trend,Patterson, Precision and BME with no luck. Any ideas?6
Liked 333 Times in 180 Posts
I would call JE---Mahle--Manley ----Directly see if they can help you--FED 387
Liked 225 Times in 136 Posts
Trend
Liked 189 Times in 48 Posts
You could have the pins chromed to make up the differences and then hone the pin bores to the proper clearance.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Liked 348 Times in 152 Posts
Make sure you specify either spirolox or wire locks.
As said, try Mahle or Manley
Phil Molski PMR Performance S/C 1623 |
Thanks Class Racer. Found some 879.at Trend
