#11 |
Liked 348 Times in 152 Posts
SBC is 23 degree, SBF is 20 degree, etc.
What's BBC, 24 and 4, I believe, on the intake side.
Phil Molski PMR Performance S/C 1623 |
#12 | |
Liked 5,124 Times in 1,953 Posts
Okay then , if that's what it now means. But it's not what it used to mean, and I go back over 50 years with S/SS tear downs. ;-)
#13 |
Liked 7,742 Times in 1,740 Posts
Ya know, NHRA is notorious for being very vague and sometimes misleading with the wording of some of it's rules. That IS intentional. Many times I have contacted Tech Inspectors for clarifications and TWICE by TWO different Inspectors I've been told "we don't want you to ask for permission, we want you to beg for forgiveness!"
I will hope that the "any valve job" means what it says and I won't be throwing out a very good set of heads. OBTW, talking about "valve (stem) angles, have you ever checked a set of SB heads after they've been cut .120 or more?
#14 |
Correct Mark, they do give you a plus or minus ONE degree
Angle milled .120 would be just shy of a degree and a half, so, yes, technically illegal, but only if they actually know how to measure
Phil Molski PMR Performance S/C 1623 Last edited by pmrphil; 05-31-2024 at 03:12 PM. |
#15 |
Liked 705 Times in 219 Posts
Wouldn't angle milling the deck surface of the heads be a lot less work to basically accomplish the same goal?
#16 |
That's what Billy was talking about
#17 |
Question here, for anyone.
How would tech check the valve incline angle during a tear down, on a canted valve type engine....or any engine , for that matter ? I don't know, and I've never seen it done.
#18 |
Liked 348 Times in 79 Posts
Is it better to do the valve job before or after you port the heads?
Pat Clemente #1427 B/S |
#19 |
Liked 497 Times in 243 Posts
#20 |
Level the head with deck surface up, and use an angle finder on the face of the valve. Similar to checking "things" out on a floating head type of seat and guide machine. Canted valve check would be the same process.
