Old 06-10-2024, 08:44 AM   #1
AveryMcLawhorn
Liked 80 Times in 19 Posts
Default Super Stock Roller Lifters
Hi All,
Asking for more information and/or insight into the various types of roller lifters for a SBC super stock motor that turns up to 9K RPM.
I know there are needle bearings, bronze bushed, and DLC bushed. What are the pro's and con's for these lifters? Obviously I am aware that needle lifters can come apart, what about the various bushed ones? Any reason why to run a specific lifter type over the other?
Thanks,
Avery
Avery G. McLawhorn
2166 Super Stock
AveryMcLawhorn is offline   Reply With Quote
Old 06-10-2024, 12:19 PM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Super Stock Roller Lifters
Had a reputable s/s engine builder
that he did not like the bronze bushing if your going to run lite weight oil when you need to go fast.
Old 06-10-2024, 12:27 PM   #3
pmrphil
Liked 348 Times in 152 Posts
Personally have not noticed much lifetime difference between bearing and bushed, when either one fails you still have the same collateral damage inside. I have not used the DLC bushed ones.
Phil Molski
PMR Performance
S/C 1623
