Old 06-20-2024, 10:09 PM   #1
Joe Strunk
Joe Strunk's Avatar
Liked 5 Times in 3 Posts
Default Re: 302 F-F-Ford Blocks
We used the Mexican Blocks with Block fill .060 over is about max
Early blocks prepped this way are good to +/- 500 HP
The beefy aftermarket stuff is way to heavy and is overkill for the HP
A4 about the Best but hard to come by
The Later Ford BOSS blocks are good for the weight but $$
I have a standard bore BOSS service block I may be willing to let go
Good Luck!
[SIGPIC][/SIGPIC]
SS/MA 2890
Anderson & Toren Comet
Joe Strunk is offline   Reply With Quote
Old 06-21-2024, 09:04 AM   #2
Ralph A Powell
Liked 225 Times in 136 Posts
On the original Ford Boss 302 blocks are all real good EXCEPT THE D0ZE-A it is not a Square Bore casting don?t try to over bore the 4.00 inch! Others will take a 4.060 bore!
Old 06-22-2024, 07:15 PM   #3
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
The early 302 blocks like 1968 are better sonic wise than the later blocks. Don't believe anything about the Mexican blocks other than. They have the hipo main caps. You can also just buy the steel main caps and install them. Definitely fill the block. Also neutral balance saves the block. Rule of thumb is 500hp and 8000 rpm is the limit on a std 2 bolt block. For the price of an original Boss 302 block you can buy a Dart
Duane Hoven
1342 SS/GT
1347 is online now   Reply With Quote
Old 06-23-2024, 09:01 AM   #4
Ralph A Powell
Is the Dart legal! If so that?s what I would use!
Old 06-24-2024, 12:30 PM   #5
StockerStang912
StockerStang912's Avatar
Liked 21 Times in 7 Posts
Dart is legal, but if it's a Stocker I don't think an aftermarket block is worth the $$, work/effort to get accessories and headers to fit or the extra +30lbs. You'll be well under the 500hp and 8K RPM range which the early blocks are plenty good for.
Greg Viscome
193 GT/QA
StockerStang912 is offline   Reply With Quote
Old 06-24-2024, 05:15 PM   #6
Ralph A Powell
It is if you want to get to the .070 over bore! Then use .060 offset cylinder head dowels!
Old 06-24-2024, 06:34 PM   #7
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I weighed my Mexican block today. Bare block is 126 lbs with caps.
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
