Old 06-23-2024, 06:21 PM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Default Re: Air shifter
I don?t think there was anything unique enough about the PPP shifter to award a patent. There were plenty of other shifters already on the market before PPP emerged. There is plenty of business for all of them. I have the M&M in my car. There are other that look similar to the M&M as well.
Mike Pearson 2485 SS
Old 06-23-2024, 07:36 PM   #12
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
I was going back and forth between PPP and M&M and chose M&M because i liked the looks of it better. They both are very high quality units and im sure function very similar. I have had 0 issues with mine.
Jason Shepard is offline   Reply With Quote
Old 06-24-2024, 09:10 PM   #13
mnmaxwedge
Liked 172 Times in 53 Posts
I looked at M&M also but they don't make a Mopar shifter.
mnmaxwedge is offline   Reply With Quote
Old 06-25-2024, 10:49 AM   #14
Hacksaw
Liked 312 Times in 175 Posts
[QUOTE=mnmaxwedge;699040]I looked at M&M also but they don't make a Mopar shifter.[/QU If the pattern matches, other than the trans shifter bracket what else matters?
Old 06-25-2024, 01:29 PM   #15
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Originally Posted by cummins View Post
For ss 904 is there a air/ electric / nuclear/ mind controlled/ shifter that works with a tran brake/ clean neutral valve body
I use a ACD controller, co 2 system with my classic turbo action shifter, with clean nuetral, in the dakota, dart has newer style ta shifter same setup, both work great.
Eric Merryfield 1883 STK
Old 06-25-2024, 02:06 PM   #16
jmcarter
jmcarter's Avatar
Liked 3,226 Times in 981 Posts
Did Paul Forte modify your TA for clean neutral, surely not just a shifter plate?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-25-2024, 10:16 PM   #17
mnmaxwedge
[QUOTE=Hacksaw;699057]
The pattern wasn't the same with a clean neutral shifter.
Old 06-26-2024, 08:36 AM   #18
Eric Merryfield
Here she is
Old 06-26-2024, 08:51 AM   #19
Eric Merryfield
Here she is
Its not altered, for the air shift, a spring is altered. I used to run it shifting myself, which was ideal, except for the straight 2-3 was too soft and I could too easily go from 1 to 3. If I had to do it again, I'd likely alter the shift pattern with some sheet metal like some have done to keep that from happening.
Eric
Old 07-15-2024, 06:57 PM   #20
Coleydog
Liked 53 Times in 38 Posts
Clean neutral? That?s that little thingy that sticks up off the gate, make it taller if you feel insecure, why you pulling up the lever? That?s only used to go into reverse. I?m talking the TA shifter of course. Thousands and thousands of shifts and never 1-3 and never into reverse.
