Old 07-09-2024, 11:15 AM   #21
jcw31
Liked 6 Times in 6 Posts
Default Re: ppp shifter
Originally Posted by SBillinson View Post
I've got the forward (push) shift PPP for a C4 and the reverse (pull) for a Protrans 727/904. The forward shift doesn't have a positive stop for 2nd gear despite having a lip on the detent pattern. You may be able to adjust the spring in the handle or find some other way to make it a positive stop, but mine's an air shifter so I never really cared.
I found that if you just hit the lever with your palm or finger--like a slap stick shifter--it'll go right into 2nd gear and not skip to 3rd.
thats exactly it . Thanks !
jcw31 is offline   Reply With Quote
Old 07-09-2024, 05:03 PM   #22
Barry Polley
Guest
Posts: n/a
What is the proper method for accurate adjustment?
The primary check is for full travel from park to the opposite end of the shift pattern. Then verifying that all forward gear positions are in a relaxed condition is recommended.
From PPP FAQs
Old 07-09-2024, 06:11 PM   #23
Alan Nyhus
Liked 799 Times in 236 Posts
Had this exact problem with one I worked on. PPP showed less than z-e-r-o interest...never returned multiple calls, emails, etc. Tossed the junk original spring and sourced some spring stock from McMaster Carr. After a bit of tinkering with spring length and preload...problem solved. -Al
"That'll never work....."
Old 07-10-2024, 12:30 PM   #24
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
heard the same from many that had issues over the years and this is why I never considered this shifter when I decided to swap out my Turbo Action Cheetah shifter 4 months ago.
I also considered the M&M and Motion Raceworks shifters which are available for both 2 and 3 speed trans, both very nice and made in the USA.
Old 07-21-2024, 02:21 PM   #25
Dwayne Scheitlin
Liked 20 Times in 6 Posts
The side plates on your PPP shifter are worn out. Replace the side plates and it will work as advertised. I know because that happened to my shifter.
Dwayne
Dwayne Scheitlin is offline   Reply With Quote
Old 07-23-2024, 12:38 PM   #26
House of Darts
Liked 20 Times in 15 Posts
I'm fighting a similar issue with the shifter hitting 3rd but the trans is not fully engaged. PPP solution was to lube the cable(which I did) or get a longer cable. The PPP seems to be sensitive to the bends in the cable.
House of Darts is offline   Reply With Quote
