Liked 759 Times in 379 Posts
Pressure can only be increased by changing the pedal ratio or by decreasing the master cylinder bore.
Liked 3 Times in 2 Posts
The bias is likely volume not pressure.
Liked 133 Times in 76 Posts
How does it put more volume to one port? Same bore size operated by the same pedal stroke.
Liked 23 Times in 13 Posts
The piston is elongated with a chamber in the middle section. The forward chamber is pressurized by the front of the piston, full bore diameter.
The middle chamber is also pressurized but has reduced area due to the middle diameter of the piston carrying across to the forward piston. At any given pedal force, reduced pressure is generated in the rear chamber. |
