Old 08-26-2024, 11:32 PM   #1
1700camaro
Liked 226 Times in 115 Posts
Default Re: Hoosier drag radial vs bracket radial
Take that tidbit to your therapist & maybe he or she will pretend to give a shyt.
Now, back to the original question of what's the difference. You come up with the clueless comment.
Originally Posted by 1320racer View Post
I believe it's marketing.
The factual comment is:
Originally Posted by 1700camaro View Post
The Hoosier bracket radials are different than the drag radials:
They have a softer compound than even the C06 & are a heavier tire even though they're slightly narrower.
1700camaro is offline   Reply With Quote
Old 08-27-2024, 07:31 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Conjecture NOT a factual comment!
Old 08-27-2024, 12:05 PM   #3
1700camaro
Larry & Agder,
The Hoosier link shows the two tires & their compounds. Then using Hoosier compound chart, you can see the DBR compound is on the soft side of the C06 compound.
As for the different weights, you can look that up in Jeg's. They have the DDR at 32 lbs. & the other drag radial at 25 lbs.
https://www.hoosiertire.com/assets/Drag21.pdf
Old 08-27-2024, 12:18 PM   #4
1320racer
1320racer's Avatar
All you know is the information available online to the public. You are not privy to Hoosier’s engineering, production and marketing meetings.
Old 08-27-2024, 05:59 PM   #5
1700camaro
Old 08-28-2024, 12:34 PM   #6
Woodfin
Liked 274 Times in 105 Posts
I will report the results next spring. My self-imposed goal is to have my S-10 on track by that timeline.
Old 08-28-2024, 12:36 PM   #7
1320racer
1320racer's Avatar
Larry as long as your track’s starting line is prepped, you’ll love them.
