Liked 66 Times in 31 Posts
What causes the front pump seal to blow out. I just got this transmission and put it in my car and it blew fluid everywhere. The seal was out of the pump completely. I don't know much about the thing like who built it. I thought it was odd that the cooler ports were plugged.
#2 | |
Liked 520 Times in 176 Posts
Without knowing whether this trans is in a Stocker or a Super Stocker, internal pressure will push out the front pump seal. GM has a retainer for the front seal but you might need to check that the vent for the case isn't blocked or restricted. Depending on who actually built the unit and who's valve body has been installed will determine why the cooler lines are plugged. My McClay unit has a loop, my Leon trans is plugged. You might want to reach out to Mark Yac. that comes on this site, he might be able to give you some guidance. If someone in Mike's area knows of a good builder, maybe you could chime in here and get Mike some help. Have a Good Day. Respectfully, Henry Kunz 1534 H/SA |
Liked 5,128 Times in 1,956 Posts
Mike, I've never seen a chronic case of seal blowout. Depends on how much pressure is behind it, and why. Is it a 350 converter conversion? Has the stator support been replaced? never used Loctite on a front seal but I suppose you could.
Most transmissions have an internal cooler bypass for cold climates. Usually one would completely remove the bypass and let the fluid make the loop internally. Not a big deal, if you don't want to run a cooler..I do, always. . One run ,every three or four hours? No big deal... Gas and go, turn 'em and burn 'em in a hot climate, late rounds? Different story..
Liked 239 Times in 114 Posts
Two ways to cure this problem. first is to make sure the converter bushing is in good shape and has the proper clearance to the converter neck, second is to open up the drain back passage that vents behind the converter seal . A 200 has a cast iron pump and the press fit for the seal is pretty robust. The 4L60 had an aluminum pump, and had a problem losing the converter seal , so a seal retainer was designed that pressed on over the seal to retain it, due to loss of press fit as the aluminum pump expanded as it heated up. Cast iron pumps don't usually have this problem. Your problem is probably caused by excessive leakage getting into the pocket behind the seal, so that clearance between the converter neck and the bushing is probably where that leak is coming from. Let us know what you find !
This is a G/SA car that is not real fast. I did replace the seal and it was a tight fit. I also found that the converter snout looked burnt so I put a new converter in it. I will run it tonight and see what happens. It looks like the stock pump and maybe stator too in it.
Ran the car last night and did not have any issue with front seal. We will see how it does at the national in Ennis. Hope it?s faster than the turbo 350 I just took out.
Anyone know the weight difference between a turbo 350 and a metric 200. Just wondering if I need to add weight.
Liked 333 Times in 180 Posts
Totally stock 350 is about 122 pounds whereas a totally stock 200C comes in about 96
Thanks. If it?s that much I better add a little weight tonight so I don?t get dq?d.
Mike , take your car , race ready down to the scales before you make a run, and weigh it. The scales are usually open, and it is a lot better not to guess when you make your first run ! Good luck
