Old 10-14-2024, 05:48 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: LT1 Opti spark question
Originally Posted by e vassar View Post
I have read that some LT1 racers are disabling the processor in the opti spark distributor so it basically is only a cap and rotor distributing spark to the plug wires. I believe this is called "batch fire" we have a crank trigger a BS3 and 7AL3 . So do I need the processor in the opti spark? How will the BS3 pulse the injectors without the signal from the opti spark?
Thanks
I have rebuilt several Opti's.
Stopped buying new ones if the Led Trigger is good.
Also a working Opti has the Rotor Clocked Correctly.
For Drag Racing, Remove everything.
If you have a good Trigger unscew it and save it.
Tape or Plug the Opening.
Save the Trigger Wheel if not bent.
Install the Rotor and Locktite the Screws.
Take the Long Electrical Connector that goes into left side of the Opti.
Cut the Wires and Install the Connector.
Plugs that hole.
Prevents water or moisture from gettng inside the Cap and Rotor.
There are two small tubes on the bottom.
Put a Rubber hose on Both.
Let them hang.
