#191 |
Liked 460 Times in 59 Posts
It's worth noting that 60' beam placement is normally about 10" above track. In this position it's not only the front or rear tire that can trip the beam. Depending on how the car leaves it may not even be the same location on the tire tripping it every time.
#192 |
Liked 867 Times in 165 Posts
I'm having a very hard time understanding this 60ft change to ET change thing. Now, if you were to tell me that your car slows down in ET with a big wheelie, then yes, I would agree that you are going to have a slower 60ft by tripping the beam with a different part of the car, and you'll have a slower ET because that's how the car acts. However, to say that the 60ft clock itself has an effect on the ET, that is what I can't figure out. Bear with me, I am just a "kid," but the timer is activated once the starting line beams are broken, and as each photocell down track is "tripped," the corresponding time from the start is recorded. And the MPH works by finding the velocity given the time to travel between the speed trap and the corresponding ET trap. If a car were not to slow any ET by tripping the 60ft clock with either the front or ear tire, the 330 time should be the same. What will change is the 60ft - 330ft interval. Sometimes intervals can show some interesting things.
1189 F/SA Defunzalo Racing Enterprises |
#193 | |
Liked 114 Times in 29 Posts
Especially on a car that sits lower in the front to begin with. Depending on where i come down from the wheelie it could be the front bumper, it could be a header collector, it could be the door. In my opinion, the 330 time is a more accurate measurment of how quick the final ET will be. |
#194 | |
Liked 759 Times in 379 Posts
as I've stated numerous times here
That said, how many replying here have the car that can no mind have done an A-B-A with their car on the same day, letting it fly, breaking the 60 foot beam with the back tire then tie down the front, shock extension on full tight, travel limiter set for the minimum tire drop an make a pass with no more than a few inches of day light under the front tires? We know Stan hasn't ![]() Last edited by 1320racer; 10-18-2024 at 11:30 AM. |
#195 |
Liked 657 Times in 187 Posts
I have, but you called me clueless . I'm not saying your car or my car is the right or wrong way just showing different sides of my real world experiences. And that every car is not the same. My timeslips prove in my situation my car does not slow down, it runs about the same et big wheelie or little wheelie . Now my car tied down is way slower to the 60' for some reason.
I have also caught something like the front bumper before or the deflector etc. from a bounce , and have had a faster 60 foot and a slower 330' just different examples 60' can change and car still run same number because where the 60 foot is catching the car like explained above.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA Last edited by TOSTO RACING; 10-18-2024 at 11:03 AM. |
#196 |
Post your A-B-A time slips from the same day where you have done what I stated. I'd also like to see a photo of your shocks and limiter
![]() ![]() Last edited by 1320racer; 10-18-2024 at 11:19 AM. |
#197 | |
Liked 129 Times in 53 Posts
I know your mission is to get clicks on the site for the boss but just give up on this and go to another thread. 60 foot times means nothing to a stock suspension when you do big wheelies,330 does
Stop global whining |
#198 |
Liked 226 Times in 115 Posts
I don't have nor done the A-B-A same day test. Seeing you are so passionate on the subject. Share your A-B-A time slips from the same day.
#199 | |
I posted my experiences earlier. And have talked about it. I honestly am done here. If I ever see you at the track you are more than welcome to look at all my data and car anytime .
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#200 |
so you can't, no surprise. You should have been done with this thread along ago.
