Old 11-21-2024, 07:13 PM   #1
Liked 10,906 Times in 2,255 Posts
Default Re: 66 or 67 Fairlane
I have a 66 GT hood and some fenders if that may help.
Old 11-22-2024, 12:30 AM   #2
Rory McNeil
Liked 1,110 Times in 304 Posts
The instrument cluster, dash pad, steering column, as well as the grill, emblems, tail lights, side trim,and if claiming a GT/GTA model, the hood,are all different between a 66 and 67 Fairlane. Curious why you would prefer the 67 over the 66, same engines for both years.
NHRA 6390 STK
M/S 85 Mustang
Old 11-22-2024, 03:37 PM   #3
Stephen & Horace Johnson
Liked 164 Times in 54 Posts
just claim it as a 66, why all the changes ? it?s same both years.. the 390 combo is the better combo? good luck
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 11-23-2024, 02:51 PM   #4
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
The 390/335 in 1966 vs the 390/320 in 1967 are the same engine. Both are refactored at the same rating.
The difference is in 1966 it was only available in the GT and GTA bodies. For 1967 that engine was available in all Fairlane body styles
Travis Miller is offline   Reply With Quote
Old 11-25-2024, 11:37 AM   #5
Daves1965Falcon
Im just trying to find out the best combo. Im really leaning more towards the 427the more info and research im finding Thanks
Daves1965Falcon is offline   Reply With Quote
Old 11-25-2024, 03:10 PM   #6
Jim Caughlin
Liked 805 Times in 245 Posts
You start considering building a 427, I don't think the cost of a replacement grille is going to be a big issue in your overall budget...
Jim Caughlin is offline   Reply With Quote
Old 11-26-2024, 07:54 AM   #7
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Theres a c7-f on ebay...... very cheap compared to a HR intake!
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 12-24-2024, 02:51 PM   #8
cobrajet2
Liked 11 Times in 4 Posts
Could you run the 390 combo in a 1966 Comet Post Sedan? Not listed in the current rule book, but I think it used to be a long time ago. One would have to petition NHRA? Sorry, did not mean to hi-jack, just thinking out loud since the question of '66 v '67 came up.
cobrajet2 is offline   Reply With Quote
Old 11-25-2024, 11:33 AM   #9
Daves1965Falcon
[QUOTE=Rory McNeil;705937]The instrument cluster, dash pad, steering column, as well as the grill, emblems, tail lights, side trim,and if claiming a GT/GTA model, the hood,are all different between a 66 and 67 Fairlane. Curious why you would prefer the 67 over the 66, same engines for both years.[/QUOTE The GT & GTA were the same engine but the 500xl was not. The 390 that was in the xl was smaller compression smaller lift camshaft and no aluminum intake. There is only one aluminum intake you can use in 66 and its for the gt or gta in 67 there is 2 aluminum intakes that you can use. both are very hard to find. Im just weighing all options.Thanks
