Old 11-28-2024, 06:43 PM   #1
grpayne204
Default Chevy TPI Heads #14101083
In search of a set of heads for tuned port injection small block cast #14101083. Call me if you have a set you would be willing to sell. 7065122503
Trey Payne
204T
grpayne204 is offline   Reply With Quote
Old 11-29-2024, 04:18 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Chevy TPI Heads #14101083
14101083...87-up...350..........Gen.I, also used on crate motors, 285 or 300 hp, 64cc
chambers, 72' center manifold bolt
angles
Is this the head you are looking for?
Adger Smith (Former SS)
Old 11-29-2024, 05:14 PM   #3
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
angles
Those 083s were not on the crate motors. They might have been on some of the very early crate engines back then but quickly went away. Instead, they used the 217's which were the same part number, but different casting #. I still have the sales receipt when I ordered a new set of 083's from the GM dealer only to have 217's in the box. Dealer told me the "replacement head" for the IROCS/Z-28's/Formula Firebirds was the 217's.
The 083 were on 88-91 350 cu in Z-28s, Formula Firebirds and IROC's. And they are rare. Most of those Camaro and Firebirds had 305's in them (081 Head). The boat motors had 217's....
Don't use the 217s, they are even thinner than the 083's, which have thin decks and are made out of pop can material. Both the 083 and 217 are of the scalloped type, similar to all the water leaking 624's that we used to run. The 083s are an OK head for a Stocker but hold your breath kind of head for Superstock.
Oddly enough, if you look in the guide you will see some other numbers listed with the casting #;s. One of those #'s is 10159552. Seems to be a 552-casting number but it's not. Turns out that is the Part Number when ordering a new 083 head . (Below)
Jeff Niceswanger 3740 SS
Old 11-29-2024, 05:33 PM   #4
Jeff Niceswanger
Back when you could still order them.
Name:	New 083 Invoice Small.JPG
Old 11-30-2024, 11:42 AM   #5
Signman
Liked 269 Times in 99 Posts
Those heads have become rare. Back in the 2000s it was known they were pretty good for the street kids were hand porting them so those are ruined if around. My brother had a boat with a 350 when we went through it had them BUT must have been used cores valve guides were opened up for larger stem valves. Beware you may be looking at replacing valve guides with a set of boat heads.
Old 12-01-2024, 09:44 AM   #6
HR9121
HR9121's Avatar
Good luck Trey I found a set about 2 years ago and paid $500 for them and another $250 to get them shipped. They are the unicorn that we're all looking for these days.
James Williamson
W200 J/SA. SS/JA
Old 12-01-2024, 12:15 PM   #7
Jeff Niceswanger
When looking at your new casting, have a look at the water transfer holes in the decks. (The ones we always have welded up solid). You can look thru the holes and see how thin the 083 decks are. Some of these castings are super thin in those areas and they will end up like mine did. After 3 times of having various areas welded back up and repaired... I finally scuddled them. 8000.00 for a year-old set of boat anchors.
Name:	Broken 083 Small.jpg
Old 12-01-2024, 01:04 PM   #8
Signman
There are some listed on ebay motors "pricey"
Search this Thread:
Advanced Search
