stocker. w/ stocker cam short lift long duration.
Liked 8,212 Times in 1,536 Posts
Could possibly be a vacuum leak ?? Has the intake been removed lately ?
Liked 132 Times in 52 Posts
Spring shouldn’t affect idle. Power piston is tied to main circuit not idle circuit if pulling fuel from main circuit at idle throttle blades are to far open.
Checked for vac leak w/ smoke machine.
As for the pistons. I thinking maybe a little pull over . Well I'll put it back together as it's a backup and work on it next spring. thanks all who chimed in. John B645 |
Liked 110 Times in 29 Posts
PM sent
Liked 231 Times in 107 Posts
Put flat edge on top base sitting upside down. Must be good and flat.
Liked 778 Times in 142 Posts
Get a drinking straw, cut it down to about 4? long. Place it in the vent stack
at abslight angle to catch the power piston/primary metering rod hanger arms. Note the length sticking up. Now start the engine. It should pull the power piston down and the straw with it. If it goes down and stays down At ?idle? (yes I understand it won?t idle well on its own but you get the idea) then that?s not your problem. Have you drilled the holes in the primary blades yet? Kp |
