Old 05-27-2025, 10:22 PM   #1
Woodfin
Liked 281 Times in 108 Posts
Default CO2 10oz refill, 2025 revisited
Today I visited four welding supply stores. None of them will refill the 10-oz CO2 cylinders. In addition, I asked about buying a large cylinder so I can do my own refills. All stores said they only exchange if you already own the cylinder. I asked about buying a new cylinder, and was told $300.00 - $400.00
So my question is, what is the 2025 solution to this dilemma?
Old 05-27-2025, 10:55 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: CO2 10oz refill, 2025 revisited
try a paint ball place
Old 05-28-2025, 07:26 AM   #3
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Yep. You can also look around for an air rifle shooting club/team.
Furthermore, nitrogen or argon also work just fine.
Kp
Old 05-28-2025, 08:15 AM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Buy a 20lb bottle with a dip tube
Buy 2 ball valves and braided steel lines and the correct fittings to connect to the large bottle and the 10 oz bottle
Go to you tube and watch a video or 2 on how to fill a bottle
I made up this setup and could fill a bottle very easily and quickly without using a scale
The parent bottle pressure is not high enough to over pressure the 10 oz bottle and quickly fills it. You can get many refills out of the big bottle.
I watched my pressure gauge even on the hottest day and the pressure never was high enough to blow the safety relief valve
I had 3 bottles and could change one in a couple minutes.
The better solution is a K&R on board air compressor
I gave my refill setup to my friend and when I needed to use an air shifter bought the K&R and there is no need for bottle refills....
Rich Biebel
S/C 1479
Stock 147R
Old 05-28-2025, 10:15 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Just take the regulator off and use compressed air. I pump my air bottle up to 135 psi with mt Ryobi inflator. works perfectly.
Mike Pearson 2485 SS
Old 05-28-2025, 05:12 PM   #6
cordoba13
cordoba13's Avatar
Liked 9 Times in 6 Posts
I bought a 40 lb bottle (without siphon tube) and adapter fitting from welding supply store. made a stand to put bottle upside down, attach 10 oz to big bottle open valve done. you can use a fish scale to wight bottle. if you fill it to much Valve will blow-off welding shop has valves
gary
cordoba13 is offline   Reply With Quote
Old 05-28-2025, 08:10 PM   #7
tomcraig
I use a place that refills fire extinguishers. In and out in about 5 minutes. they also refill scuba tanks and soda stream bottles. look them up.
tomcraig is offline   Reply With Quote
