Old 06-15-2025, 09:39 AM   #1
Fatman
Default Lowest fiction 9" Diff bearings
Can anyone recommend a set of low friction bearings for a 9'? R&P and carrier bearings please. Thanks.
Fatman is offline   Reply With Quote
Old 06-15-2025, 02:38 PM   #2
SSDiv6
Liked 1,589 Times in 583 Posts
Default Re: Lowest fiction 9" Diff bearings
The lowest friction bearings are Ceramic.
Performance Bearing
http:https://www.performancebearing.com///
Also, Mark Williams and Strange offers Ceramic bearings.
A lower cost option is MicroBlue coated bearings.
http://www.microblueracing.com/index.html
Old 06-15-2025, 02:43 PM   #3
Woodfin
Liked 288 Times in 109 Posts
Fatman,
My Son and I have experimented with such things, including ceramic bearings. We did not see any measurable difference.
The key in my experience is a very light pre-load with both pinion and side bearings. With the pinion bearings, use a solid crush sleeve kit and select a shim stack that only provides slight pre-load. [it will mean taking it apart several times to sneak up on it.]
With the side bearings, use a spanner wrench so you can get a good feel for the clearance. Have each side just snug then go to the next hole that will catch the holding tabs.
Once the assembly is complete, it should be very easy to turn. It should be able to easily turn with the ring gear. Also, you will notice the car will be very easy to push.
Woodfin is online now   Reply With Quote
Old 06-18-2025, 10:15 AM   #4
james schaechter
Liked 1,436 Times in 299 Posts
Smile Re: Lowest fiction 9" Diff bearings
Wayne Henderson at Indy Gear is a trusted and experienced source
My personal experience is that there was more e t switching to a Gleason Gear set up and zero drag brakes than there was with the ceramics.
Ceramics are good in many applications not all. Most guys that say they don?t help probably are hitting a drag downstream from them. That being said, they are not magic. Don?t do this type of change first, do the bigger impact stuff then consider ceramics.
My 2 cents anyway
James Schaechter 3163 STK
