From the NHRA 2025 rule book, Under Stock :
" NHRA-accepted adapter plates permitted." Anyone know where to find the listing ? Asking for....myself.
Liked 734 Times in 385 Posts
Mark,
I don't have an answer for you, but that line goes back to a min of the 2017 Rule book. Stan |
Liked 9 Times in 5 Posts
The rule goes back to at least the 2000 rule book, so it's been there 25 years.
#4 | |
Liked 1,604 Times in 583 Posts
https://www.holley.com/brands/quick_.../bellhousings/ |
Thanks for the research, guys
The quote is from the automatic section though. Can anyone go back to where any transmission from same manufacturer allowed? Did it ever say it must bolt to the engine, or was that just understood?
With all this discussion about transmissions, and the fact I have a SBC pattern 904 case I'd like to sell, I went back and looked through the old rulebooks (missing a bunch) to understand how it has changed for both stick and auto.
- in 1988 both stick and auto were required to have same year make and model as the car. - aftermarket stick transmissions allowed in 1989 - any model automatic from the same manufacturer with the same number of speeds allowed in 1991. Adapters prohibited - OD gear not required and redrilling to adapt prohibited comments added sometime between 95 and 97 - NHRA accepted adapters permitted sometime between 98 and 2000 - sometime between 2010 and 2020 3 speed automatics allowed. Interesting that aftermarket (stick) transmissions have been allowed for 36 years and it has been 34 years since a stock automatic has been required. For a few years it did specifically have rules that would say the transmission must bolt up. Now almost any transmission can be used, and with proflites the components are not from the same manufacturer anyhow. It's also interesting how much wording about shifting and other things has been added. So my SBC 904 case has no market and I think that Supra is no different transmission wise than any other stocker. And I think it is great to get a newer Stock Eliminator running in the conventional classes. |
#7 | |
Liked 24 Times in 11 Posts
Liked 376 Times in 201 Posts
Yac they should be on the NHRA Accepted Products List (if there are any currently accepted), NHRAracer.com on left, under TECH heading, Accepted Products List...Scrolled the list contents and only found Stk/SS Accepted bellhousings 3 there and all GM and all were JW Transmission and all on Pg 54. No heading there for Accepted Adapters so a call to the tech department may be in order.
Or, call JW Transmission, tell them what you want to (adapt or matchup), and they certainly know how to get it added to the list.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 06-18-2025 at 06:08 PM. Reason: Additions |
Since it appears that a Toyota is allowed to use a GM automatic transmission, because supposedly, at some point some BMWs had GM transmissions, I wonder now if Fords will be allowed to use an adapter for a Turbo 200, since in the early 50s, Lincolns were available with a GM Hydramatic . Or is such a thing only allowed on vehicles that don`t exist in the Classification Guide?
Liked 227 Times in 74 Posts
Rory the way I see how the Toyota got a gm trans. Ford should be able to also. Ford owned jaguar for several years, jaguar's did use gm transmission for several years. This is not different then what was just approved by nhra. Ford should be able to use any GM trans, have adapters made and have them approved or bellhousing for the 200.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
