Old 06-11-2008, 06:20 PM   #1
neb5445
Default Re: Attn 396, 375hp iron head racers
Most 396/375 racers are able to run well under the index, getting hit 5 hp will not change this. Take the hit and get on with more important issues, what ever they may be.
neb5445 is offline   Reply With Quote
Old 06-11-2008, 06:34 PM   #2
hadtobethere
Talking Re: Attn 396, 375hp iron head racers
maybe the 402 needs a hit........
hadtobethere is offline   Reply With Quote
Old 06-11-2008, 07:20 PM   #3
Jim Cimarolli
Liked 166 Times in 46 Posts
Lightbulb Re: Attn 396, 375hp iron head racers
Yeah, that should fix it all.
Jim Cimarolli is offline   Reply With Quote
Old 06-11-2008, 08:23 PM   #4
GENE BUELL
AFHS, this post reminds me of SURVIVOR. Be thankful you have an average, last time I was hit it was NOT during their scheduled rounds.
A very unfair system, slowly finding it's way to the masses............
Gene Buell 7426 STK
Gone Jeepin'!
GENE BUELL is offline   Reply With Quote
Old 06-11-2008, 08:31 PM   #5
Liked 1,836 Times in 417 Posts
Originally Posted by clutch man View Post
How heavy are we going to get these cars before safety and breakage is an issue? But if the 396 gets more HP can it only run AA/sa or A/sa, or will it still be able to run B?
It depends on the year, which heads (aluminum or iron), and which body.
Old 06-11-2008, 09:42 PM   #6
OLD INJUN
most 396/375 Racers Are Able To Run Well Under The Index, Getting Hit 5 Hp Will Not Change This. Take The Hit And Get On With More Important Issues, What Ever They May Be.
The 70 Camaro With The 402 Needs To Get Hit Also !
OLD INJUN is offline   Reply With Quote
Old 06-11-2008, 09:51 PM   #7
Jim Cimarolli
Yeah, I think your'e right on that uh, is it engine?
Old 06-11-2008, 11:20 PM   #8
Keith Lynch
Hadtobethere, comon ol buddy I took care of the 402 years ago and it just keeps coming back! LOL How about this: 396/375 cast@ 395......402cast@400.....396 alum@405......428/367@390. Should make for some good all out class racing. Where is Farmer when you need him?
Jeff, yea lets lynch em!!!
Keith Lynch 5035 STK
Keith Lynch is offline   Reply With Quote
Old 06-11-2008, 11:57 PM   #9
Keith Lynch
Wink Re: Attn 396, 375hp iron head racers
What happened to the new AHFS rule about the average being lower for a large number of cars with the same combo as compared to a single combo car? I thougt NHRA made that change this year? Or was it recinded? I'm way to old to keep up with the AHFS.......of course, Jim, you knew that already.LOL
Old 06-12-2008, 02:18 AM   #10
Oh, that's the way it works Keith, the MORE cars running a combination the LOWER (less under the index) their average has to be for them to get HP. The FEWER cars running a combination, the HIGHER (more under the index) their average has to be for them to get HP.
Not that Keith really needed it explained, it's more of a joke between us as we've discussed this several times. It's always the reason I give him when he asks why we don't run the 396-375.
It does not seem to be so equitable a situation. But the neither is a single person, or a "HP committee". Introduce the human factor, with politics, friends vs. enemies, grudges, and possible factory pressures, and you have a mess.
So a more popular combination, even though not as fast as a less popular combination, is more likely to see a heads up run (because there are more cars running that combination), there for needing to go fast more often and hurt their average, will get HP easier and sooner. Where as a less popular combination, even faster than the more popular combination, is less likely to see a heads up (because there are fewer cars running that combination), there for not needing to go as fast as often, will take longer to get HP, and will get less HP each time unless they go 1.4 under, even though it is a faster combination with a softer factor.
This thread is a perfect example. The 396-375, with or without aluminum heads, is one of the most popular combinations in Stock, period. It's in 67-69 Camaros, Chevelles, and Novas and runs in AA thru D in most cases. Now, there are cars and combinations that will easily go faster than the 67-69 396-375 cars and combinations. But not nearly so many. So, barring someone accidentally triggering an automatic hit with a 1.4 under pass, odds are the 67-69 397-375 combinations will be hit several more times before the faster combinations with fewer cars.
To be even close to fair, NHRA needs to either make the average required to cause a HP hit the same for everyone, at the very least, or swap it around so that a combination with more cars must average farther under the index than one with fewer cars.
It's just another one of many screw ups and loop holes in the current AHFS setup. And why the AHFS doesn't REALLY work like it should.
