Old 06-25-2008, 10:52 PM   #2
mannymen
Liked 13 Times in 7 Posts
Default Re: Front Suspension help
The new dbl adjustable AFCO's will require that you grind the LCA's. Welding will most likely be involved so that you can reposition the lower shock mounting holes. If someone is doing the work for you it will cost you around $1200-1300 for the LCA modification and the shocks together.
N/A
mannymen is offline   Reply With Quote
