Old 06-26-2008, 05:30 AM   #18
Grant Eldridge
Grant Eldridge's Avatar
Default Re: Considering going Stocker Racing
Lots of great advice already posted. Might be a good idea to look at your local competition in the class you hope to run and first decide how fast you need to run. If you can get away with .5 under, you might be able to carefully put together a car with a good combination, decent machine work and not too expensive parts. I started out with used TRW pistons and flogged it down to .6 under after a year. But, to go 1+ under, in my opinion, everything in the short block had to go high dollar, index crank, high dollar pistons, exotic ring package, many thousands of dollars more just in parts plus more machine work, etc. Now, to go 1.20+ under you'll need expensive step or better headers, merge collectors, great trans and converter, excellent shocks, quality traction device, radials, high dollar carb, mondo fuel system, etc. These are just examples, there's lots more but you get the idea...To figure all this out, you'll need tons of great advice from guys that are fast, and tons of money to cycle multiple parts through the car to determine what works best for your particular combination. For example, I cycled 7 converters through my car in one year to get the best one, then went to a metric trans and bought three more to get one I felt worked well, these are around $1000. each, of course the others can hopefully be sold to get some money back. The same goes for most of the other parts on the car, you have to experiment, it's a lot of hard work, time and effort unless you are very fortunate and get it right early on. Someone posted to do it once and buy the best first, great advice! Otherwise you're re-doing each system over again as you learn and improve. My fuel system went from small to medium to large pump, then large to larger to return style for lines and regulators. If I'd put the best stuff on first, I'd have saved money and time, as well as eliminating a possible problem area. Not to discourage you, it's very rewarding if you enjoy the challenge and can invest the time and money.
My opinion, buy the fast car where someone has done all the above, you'll be years of effort and many, many thousands of dollars ahead. There's a limited market for these specialised cars, so there are cars available if you look that really should be much more than what they will actually sell for in today's market. Just my 2 cents worth....
Grant Eldridge is offline   Reply With Quote
