Liked 1,943 Times in 584 Posts
What is the recommended rod bolt torque spec for small block Chevy small journal OEM rods. 283 style. Aftermarket bolts... Thanks...
Mike Pearson 2485 SS |
Liked 1,847 Times in 418 Posts
Which aftermarket bolts?
Alan Roehrich 212A G/S |
I think they are ARP bolts. As we remember the tourque was 43 ft lbs. The bolts have a dimple for a strrech gauge so they are a premium bolt.
ARP bolts will have ARP roll marked into the bolt head.
Thanks, I guss there not ARP bolts. Maybe MR Gasket???? Anyone know what the torque is for the factory bolts are?
The factory torque is about 32 to 35. However, that will not properly load an aftermarket bolt, and will likely cause a failure. Usually SPS marks their stuff just like ARP does. I'd be VERY hard pressed to use an unknown bolt. If you don't know what they are, get a machine shop to put some ARP bolts in for you.
Liked 880 Times in 311 Posts
What kind of nut do they have?... Footed or crush lock/crimped? Stock for 11/32 bolt is 35 w oil
Adger Smith (Former SS) Last edited by Adger Smith; 06-29-2008 at 09:22 PM. Reason: SP |
After researching a little more They are either ARP high performance rod bolts or pioneer bolts. Looks like both manufacturers recommend 40 ft lbs. The nuts are a standard thread no locknut.
Mike,
The Pioneer for that engine use a crimp lock nut. It is crimped on 3 sides at the top of the 1/2 in socket sized nut. I have 2 sets of these in stock & both are alike. The ARP should have a footed style nut. The pioneer torque is suggested with oil. I think the ARP is with Moly. I'll have to look that up when I get to the shop. Most SPS bolts are marked on the head of the bolt.
Adger Smith (Former SS) |
