Old 07-02-2008, 02:41 PM   #11
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Default Re: An Idiots Guide to Super Class Racing
That's just my point Eddie. You just spent a bunch of money to go FASTER, but you're not running any QUICKER! You're still running 9.90 ETs, and the ONLY reason why you had to do this was so that you could chase more often. Take away the electronics and throttle stops, and I'm guessing your motivation to speed your car up from a car that could run 8.90's to 7.90's probably goes away (unless you have some T/S racing in your future).
I'm no different. I have another small block in the works that should be able to make my car run about 8.90s. At that point, I MAY run more S/G races, but that's not a given, and I very well may stay in S/St. Is this necessary? No, but I do feel that it will give me a competitive advantage. Again, if there's no such things as throttle stops or electronics in cars (or if a speed limit were put in place), the ONLY reason why I'd be building this new motor would be to move up to S/C. My car in more than fast enough to run S/G now, just not in today's day and age of starting line throttle stops with massive amounts of time in them.
What good is an 800hp+ motor going to do me in S/G if I have no effective way of slowing it down? With a bolt under the gas pedal (or other such mechanical linkage stop) I could certainly slow the car down to run 9.90s, but it would be at much closer to the normal 135 mph required to do so, rather than the 170+ mph cars are running today.
And hopefully nobody is taking my posts the wrong way. I'm not bitching because I can't be competitive with the rules of today. I just think we could all save ourselves a boat load of money by getting rid of the electronics madness that the .90 classes have turned into, and creating a 7.90 heads-up class for those that do want to go faster. It has become a lot easier to go faster these days, but I don't think anybody would be willing to step up and say that its cheap to build a car that can consistently run in the high 7's or low 8's without nitrous. Easier than 20 years ago? Certainly, but still not cheap.
I'd better go back to lurking mode before a lynch mob shows up for me...
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
