Old 08-19-2008, 02:49 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: Pro gear users please step in
There is really no reason to run a pro gear unless you are running a manual trans. You will get better gear life from a heat treated gear. I only run a pro gear in my car because the ratio I use is only available in a pro gear. The 488 gear is very strong. You dont need a pro gear. It will save a few bucks also. The reason the teeth take a set is because of the soft alloy of the steel. They also wear much faster.
Mike Pearson 2485 SS
Old 08-19-2008, 04:06 PM   #2
ericsz
Just my one brush with Richmond Tech makes me wonder about their knowledge, They told me to set my street gear up with as close to ZERO lash as possible so I did, it lasted 10 passes. Re installed another street gear at approx .012 and has over 200 passes on it. As for pro gears the only one I ever used was marked .008 so I installed it .010 and it did just fine. Just my 2 cents. I use the Red Line Shock resistant lube too.
ericsz is offline   Reply With Quote
Old 08-19-2008, 04:15 PM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
No disrespect intended Mike, but there are applications that do require a "pro" gear, particularly those that are high HP or heavy. I used to run a "street" gear in my '70 Olds (3770 lbs.) that has a 12-bolt, but changed to a "pro" gear after a couple of failures and recommendations from Mark Williams. Naturally, a "pro" gear doesn't have the service life of a "street" gear, but it sure beats being towed off the track. Sure, a "pro" gear is more expensive, but most of the time when a gear set fails, it takes the transmission right along with it. P.S. - Mine also has a very slight noise on coast that you can hear when the motor is shut off.
Jim Kaekel 3836 STK
Old 08-19-2008, 05:02 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
If you want to go "in between", Quick Performance got some 9" pro gears made up with "street" i.e. harder heat treat so they last longer.
Old 08-19-2008, 09:00 PM   #5
40Coupe
Thanks to all who responded. Jim- I'm where you are. I certainly prefer to have a bit of insurance with the pro gear.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 08-19-2008, 09:42 PM   #6
Chris Hill
Liked 244 Times in 26 Posts
Just curious, but what is the metrology and surface treatment difference between a "street" and a "pro" gear. I know the gear guys for over the road transmissions really like a 8620 gear with a carburized surface. Gives the "tootsie roll" effect. Hard on the outside with soft gooey center .
Chris Hill
Old 08-20-2008, 09:33 PM   #7
KingReptile
The pro gears are 9310 the heat treat should be pretty close to the same with 8620, carburized with probally .060 case depth.The 9310 Pro Gears will be tempered at a higher temperature to take away the brittleness .The higher the temper the softer the gear, Pro Gear i would think would be 55rc to 57rc where a street gear will be 61-63Rc .The 9310 will have a tougher core harness then the 8620 which should help with rolling over the teeth..Hope this helps
KingReptile is offline   Reply With Quote
