Old 09-11-2008, 08:10 AM   #1
njk53
Default Re: Front Brake Drum Rivited to Hub?!?!
The rivet and the copper circular clip used on passenger car was also used to keep the drum from vibrating off of the vehicle when it went down the assembly line.
I remember reading an article in either Car Craft or Hot Rod Magazine about a company out of Texas that manufactures a brake shoe that has 30% better stopping power over ordinary brake shoes. Sorry, I don't recall the name of the place but maybe you can search the internet and find them. This would be a little better alternative to stock shoes if changing over to disc brakes is out of the question.
Nelson Kowal
Stock 345
Old 09-11-2008, 12:04 PM   #2
Jeff Lee
Jeff Lee's Avatar
search "Praise Dyno Brakes"
Jeff Lee 7494 D/S '70 AMX
Old 09-11-2008, 12:07 PM   #3
Chris Hill
Liked 244 Times in 26 Posts
Thanks for the info. I was just surprised to see the rivits.
Chris
Chris Hill
Old 09-11-2008, 03:53 PM   #4
Dragsinger
Liked 99 Times in 60 Posts
Chris,
you can cut/grind the rivet head off and punch it through the hub. [if drum replacement is required] in the "olden days" we did it regularly. Of course, there is no need to reinstall the rivets.
Here are a few things that will improver those brakes, however, as mentioned above, they are only "fair" at best.
Make sure the drums are not excessively over size. If memory serves me correctly, those brakes are 11" X 2" If the drums are more than 11.030 - 11.040 you loose the natural cam/self energizing action. Also, a premium riveted brake lining set will help. Plus, be sure to either replace or re-kit the wheel cylinders. And, do not neglect the rear brakes, just as important for them to be up-to-speed [so to speak]
Larry Woodfin 471W
Old 09-14-2008, 04:56 PM   #5
Lyn Smith
Liked 980 Times in 197 Posts
Thumbs down Re: Front Brake Drum Rivited to Hub?!?!
Dont waste your time or money on Praise Dyno Brakes. Send me a PM and I will tell you why.
Lyn Smith is online now   Reply With Quote
Old 09-14-2008, 05:38 PM   #6
Real Racer
Please tell us all why. They have been mentioned on these forums many times and I was just thinking about buying some myself.
Thanks
Real Racer is offline   Reply With Quote
Old 09-14-2008, 10:44 PM   #7
Lyn Smith
the brake shoes and spring kit is the same thing you can buy at any auto parts store,but they charge you double for it.they claim the cylinders are bigger,but the ones they sent me where the same as the ones I took out. they also had to be sent back because they leaked.other racers have had problems also.If your front cylinders have a pre formed metal line going to the cylinder ,they will not work with the cylinders they send you, so you will have to re engineer your front brake lines.
