Old 09-12-2008, 12:11 PM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: What balancers do you use
I just had my ATI rebuilt. Actually it was sent in to get a different durameter (sp?) isolater ring for a higher RPM going from Stock to SS. After ten years of use it was in perfect condition. I also saw that episode of Pinks. I knew immediately it was a balancer ring. Get what you pay for!
Jeff Lee 7494 D/S '70 AMX
Old 09-12-2008, 08:53 PM   #12
csjta
Fluiddampr
Never had a problem with the 2 I have owned
csjta is offline   Reply With Quote
Old 09-12-2008, 10:23 PM   #13
SSDiv6
Originally Posted by csjta View Post
Fluiddampr
Fluidamper is heavier than most; does not work well in all applications either. There is an SAE paper on racing balancers and Fluidamper was not that good in dampening the harmonics and/or preventing crank flex.
Old 09-13-2008, 09:41 AM   #14
69Cobra
Liked 2 Times in 2 Posts
ATI here. Our last engine had over 227 passes on it and if I didn't know any better I would've put the bearings back in it.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 09-13-2008, 11:02 AM   #15
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Fluidamper, no problems, 468 cu in, 13 to 1 compression, 4 seasons.
Old 09-13-2008, 09:13 PM   #16
Alan Warman
Thanks to every one who gave there opinion.New ATI blancer will be here on tuesday.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 09-13-2008, 11:17 PM   #17
budgetracer
I run Ati and fluid dampner-No engine issues with either. But the Ati is harder to get off-Tightest balancer I have ever run even after honed some.
budgetracer is offline   Reply With Quote
Old 09-21-2008, 08:00 AM   #18
Raceready
ATI on our pontiac engines.No bearing issues,hundreds of passes.Although we have one pontiac 400 that sits in the corner waiting for a rebuild that has a TCI rattler on it that has about 800 passes on it,1 set of bearings at about 300 passes,and that was a waste of money because they looked almost new.
Raceready is offline   Reply With Quote
