Aren't the 2 bbl & 4 bbl heads the same? The difference in compression is from the dished verses flat top pistons.
thanks in advance, John |
The 351 Cleveland didn`t come out until 1970. The 351W debuted in 69. As for the Cleveland heads, the 70-73 4 barrels had larger valves and ports than a 2 barrel version. The 70-early71 4v heads also had smaller combustion chambers than the 2 v or late 71-73 4 barrel castings.I heard that there was an oddball "smaller" 4 barrel head towards the end of the 351C`s production run, but I`ve never seen them myself.
As for the 351W heads, I believe the heads are the same for 2 or 4 barrel applications.
Liked 112 Times in 31 Posts
The '73 Cleveland 4-bbl heads had the large ports, but the same valve sizes (2.09/1.66) as the 2-bbl heads. All had the large combustion chamber.
Jerry |
Liked 395 Times in 154 Posts
HHmmm, lot of years since I even touched one, but;
2bbl 2.05 int 1.65 exh open chamber ALL (70 some cc I think) 4bbl 2.19 int 1.72 exh open chamber police int head 71-74 4bbl 2.19 int 1.72 exh close chamber adj valve train boss 351 1971 only 4bbl 2.19 int 1.72 exh close chamber hyd valvetrain 351 CJ 1971-74 Memory being what it is, I'm thinking the hyd 4bbl CJ head and PI head might be reversed. And yes when your running a stockcar and they have a cyl pressure rule, one open chamber and one closed chamber head will give 155psi(165limit) and the open will give 120....until your caught 5 races later...don't ask LOL! |
Oh yeah, something else, the 2bbl intake can fit a 17 year olds 3 fingers and the 4bbl will fit 4 fingers to the knuckle! (like sewer pipes) LOL!
good times..... |
Liked 57 Times in 33 Posts
ACTUALLY the 73 and 74 heads had the 2.05 intake valve and 1.65 exhaust valve. but if you could talk NHRA into letting us run the 2.09 intake valve pleaese let me know!!!!!!!!!!
Duane Eiskant 1354 Stock/Super Stock |
Liked 244 Times in 26 Posts
Just have uncle Carol or uncle Bill write a letter. You of all people should know that...
Actually Duane, it's 2.05/1.66.
Jerry |
I just looked up the guide to see how close I was. (blueprint guide won't open at work)
ALL 4BBL HEADS ARE 2.19!! I don't care what the guide says as obviously it's wrong. I used to run 454 chev valves in my heads because in the early eighties the chev's were like $4.00 a piece and the fords were $12.00 or something like that. I had D1/D2/D3 heads, if they were 4 bbl, they had 2.19's. Has nobody run a 73 cleveland? How come this has never been protested or the issue been raised? Yes the 2bbl's were all 2.05's x 1.65 (guide shows 1.66) The 2.09's have longer stems heehee same diameter stem though. |
