Old 09-22-2008, 02:30 AM   #1
Stephen & Horace Johnson
Liked 165 Times in 54 Posts
Default Re: At what point?
Originally Posted by budgetracer View Post
At what point do you folks think it is necessary to weld up your axle tubes? And what do I use? Also are one of those fancy rear covers with the preload bolts for the differential caps really necesary? My current 60ft. is 1.54. Thanks. I also run an 8.5 gm diff.
when you start running slicks is when you should start welding the tubes up.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 09-22-2008, 06:09 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
The girdle covers are a real plus on a light housing. .... They not only help keep the caps from deflecting, they also help keep the housing from spreading and losing preload and increasing backlash. ........As the man said "pay me now or pay me later"! ...........Tom
