Old 09-26-2008, 10:56 PM   #5
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Re: Cal Tracs Shock Mount
Bob,
I must be on the right path, I just bolted a set of extensions on earlier today. The fix for my clearance from Calvert was to take the bolt out of the mono leaf and beat the tab over with a hammer. It did provide me the needed clearance before the extensions. But with the extensions I think I could bend the tab back and reinstall the bolt.
What do you have your Cal Tracs set at for preload and do you use the upper or lower hole?
Thanks,
Chad
Chad E532 is offline   Reply With Quote
