Old 10-01-2008, 07:27 AM   #3
Larry Munk
Default Re: using a bandsaw to cut aluminum etc
Circular saw with a fine tooth carbide blade will handle the aluminum. You will need a gear drive saw for over 1/2" or so aluminum. Variable speed sawzall with a fine tooth blade for the steel. Works for me.
Larry Munk is offline   Reply With Quote
