Old 10-16-2008, 09:26 AM   #2
Jim Kaekel
Liked 534 Times in 110 Posts
Default Re: Coil spring/ control arm suspension
Using an Air Lift air bag in the right rear coil to preload the suspension will help your problem, but the best fix currently available that I have seen and used on my '70 4-4-2 is the HR Parts 'n' Stuff rear sway bar. It is a tubular, chrome moly rear sway bar with adjustable heim ends. Easy install, drill four holes and bolt it on.
Jim Kaekel 3836 STK
