Liked 2 Times in 2 Posts
I am a bracket racer only run 1/8th mile only been racing for a couple of years. I'll admit i don't have a wealth of knowledge but trying to learn more everyday.
As i understand Stock is suppose to run stock heads, intake, and carb, right? The cam has to have stock lift but any duration and lobe seperation that you want, and a lot of ET is found through the car not just the motor. I know that most heads aren't "stock" but still they obviously don't have great flow numbers. I know no one is going to give away all their secrets and i wouldn't expect you to but hoping you could give me some general answers. looking for some answers about cam selection. I run a 393 a 351W based stroker with a set of Edelbrock RPM heads which only flow about @250 at .600 I knew the heads were small when i put the motor together but money was tight and i got them for a good price. I was told buy several people since the heads were small and i was feeding 393CI to keep my cam selection fairly mild. Was told as bracket racers with low horsepower motors we should try to make up as much ET as we could in the first 330 ft and you do that by making as much torque as possible, and that a "big" cam would hurt me. I have talked to several Stock racers they told me basically they try to make their cars run as quick as they can the first 330ft and that the cars are basically done @1000ft. But from what i gather the run fairly big duration cams.I basically see my car is a stock eliminator i am head restricted and trying to run as fast as i can, same principle as stock So here is where i am confused if we both are basically trying to do the same thing and people told me to run small duration cams and Stock racers are running large duration cams. How are we doing the same thing, who is right, which approach is better. Is it because stock is limited on the lift that the have to run a bunch of duration to make up for it, and since i can go up on lift that i can get away with less duration. I'm wondering if my car would run faster with more duration or would i slow down I hope this all makes since, and some one can clear up the confusion for me. |
