I would start with 10° to 15° more duration and i think you may want to consider a 104° lobe seperation, go with an aggressive lobe, good springs such as Manley NexTek {available for solid, hyd, and rollers} springs and titanium retainers
Liked 10 Times in 6 Posts
I run a 418 cubic inch windsor stroker 10.5 compression motor with World products heads which
flow 265 at 600 intake and 210 exhaust . With this combination and a 691/668 272/280 at 50 Lunati roller cam in a 2880 lb car with 430 gears i had a 1.35 60' and the car went 10.03 1'4 mile at 133 with a small amount of moroso mechnical throttle stop (4 turns) shut off . I believe the 1/8 mile speed was 107 this was behind a C4 automatic |
Liked 2 Times in 2 Posts
Hey Superstreet what are you shifting at and how much converter do you run.
