Old 11-16-2008, 11:09 PM   #1
htwaste
Default Naturally Aspirated SBF/Turn Key
359ci Naturally Aspirated Race Engine
Engine is being sold turn key with only 7 passes since being freshened with new rods, pistons, and rings. This engine is fresh off the dyno and made just over 800 hp! Listed are a few specs and will release all other specs for serious buyer.
Small Block Ford:
*359 ci 8.7 deck SVO Block
*Bronze Lifter bores
*Jesel keyway lifters
*Roller cam bearings
*Huge NA solid roller Cam (specs to buyer)
*Edelbrock Glidden Victor Heads with all Titanium Valves (specs to buyer)
*Fully Ported by hand Super Victor Intake manifold
*Jesel Belt Drive
*GRP Pro Stock Rods
* LA Billet Crank
*Patterson Pistons
*Manton Pushrods
*Jesel ultra Trick Rockers/stands (mowhawk)
*Sheetmetal Valve covers
* Your choice of a Pro Systems or Quick Fuel custom spec 4150 carb!!!!!!
*CSR polished water pump
*front and mid plates!
*custom stock car single stage oil pump (belt drive)
*Moroso vacuum pump (belt drive)
*Moroso ultra 40 race wires
*MSD crank trigger
Engine is being sold turn key with all lines and fittings! Drop in and race!!!! Will start and run for serious buyer if needed. I also have for sale several converters and a full out Kilgore TH400 “ superlite” trans for sale. Will make a package deal if desired “The whole package” engine,tranny and converters. This set up has been 8.80’s at 2900lbs…. Add $3500 for Th400 and converter!
$14k w/carb
$13k w/o carb
Any questions please contact Joe 281 802 4283
http://www.mustangmods.com/ims/u/1582/10024/262642.jpg
htwaste is offline   Reply With Quote
Search this Thread:
Advanced Search
