#21 |
Liked 584 Times in 94 Posts
That's a really good question. And the answer is % wise, I don't know. I ran Cryo'd only ring and pinions before I started Rem finishing them. Done correctly, (and I can't stress this enough ), and in a quality machine. I think the Cryo'ing adds more to the life of the gear than the Rem Finishing. I think the Rem Finishing adds more to the performance of the gear set. Think of it in terms of the Cryogenic Process treating the gear from the inside out, while the Rem Finish removes any surface imperfections and/or stresses. One thing I've noticed. After the Rem Finishing, any machining imperfections from the manufacturing of the gear set show up like a zit on your nose. This allows you to hand polish, with a cartrage roll in most cases, the "bad spots". It's my feeling that these imperfections gone un noticed cause many of the gear failures that we see today. If you're freshing up your rear this winter, I suggest you try it. It's cheap insurance. And I pay contengencies.
The hardest thing for me to convince racers is, Cryogenic Processing has improved many times over in the past couple years. They say, I tried that, it didn't work. NO, if you haven't tried it in the past year or two you haven't tried it. Cryogenic Processing, done correctly, is now done in expensive computerized machines. Gone are the days of 5 gal buckets with dry ice, and/or beer coolers. Ask anybody doing Cryo a couple simple questions. How old is your machine? What type of insulation is used in your machine? (styroform breaks down with age ) And do you temper your parts after cryoing them? This is an important part of Cryogenic Processing. Thanks for asking. JB. |
#22 |
Liked 13 Times in 9 Posts
Bailey "FINISHED" my ring & pinion (4.86 Richmond set). I'll let y'all know if this one ever gives out. The last ring & pinion I had in the car only lasted 1 year (which granted, is several hundred runs for me).
On the performance end of things, at the beginning of the season, I ran 6.88 @ 98 mph at Piedmont in mineshaft conditions. I'll have to look it up, but I think it was a 1.41-1.42 range 60'. That was all with the standard 4.86. I just got back from another mineshaft day at Piedmont - pretty similar conditions. With the FINISHED gears, I ran my career best with my H/CM Volare, 6.757 @ 99.33 mph, with a 1.376 60'. ![]() ![]() ![]() ![]() www.finishedracing.com
#23 |
Banned
Jim i sent you a PM!
#24 |
Should parts be cryo'd then rem finished, or rem finished then cryo'd?
~Pete 1970 Nova |
#25 |
Cryogenic Process followed by Rem Finishing. Thanks, JB.
#26 |
Jim,
What is the status of this 5.00 gear?
Chuck Beach 3340 STK |
#27 |
Hey Jim,
what is the status on this 5.00 gear sets? thanks
#28 |
Liked 2,474 Times in 697 Posts
I would be interested in a couple sets if 742. I also wish I could get a 4.7 to 4.75 ratio. Thanks
