Old 05-10-2007, 01:12 PM   #1
MFR440
Liked 13 Times in 5 Posts
Default
I need a little help in getting my AVS to work right.
I am running a 70 340 in Pure Stock. I have a stumble / bog on the launch that I can't fugure out how to get rid of. I am not an expert on carbs, so any help would be appreciated.
I have tried different accelerator pump linkage positions, larger and smaller squirters, larger jets and adjusting to the air valve. None seem to completely cure the problem. The air valve seems to help best, if I put enough preload on the spring, but the stumble is still there.
Any suggestions would be appreciated.
Thanks
Mike Coates
IHRA 3914 D/PS swinger
Mike Coates
Been a while since we ran the AVS's, but you might try closing up the oval-shaped holes in the flappers, if it's legal of course. This helped throttle repsonse with our Max Wedge. We used duct tape at first, then epoxied wire mesh over the holes.
Meyer Family Racing
'64 Plymouth Max Wedge
'65 Dodge - rebuilding for ??
N/SS S/ST & H/R 3426
Meyer Family Racing (re-tired)
1965 Dodge Coronet - Steet car and Part-time N/SS
1962 Plymouth Fury S/ST #3384 - Race in Peace, Craig Meyer
MFR440 is offline   Reply With Quote
