Old 05-10-2007, 09:24 PM   #1
George Mirza
Default
Try a new spring on the air valve, sometimes when they are weak the door will snap open and not open gradually. I chased that problem on a TQ, new spring stumble was gone. AVS's can be tricky, they don't have a vacuum diaphram to delay the air valve opening.
Also the carb may be to lean, try jetting up the secondary side.
Make sure the primnary's are open 1/2 - 3/4's before the secondaries. I had one that must have been a marine unit and the primary's would open about 1/4 and the sec. would start to open. I tried everything and could not get the stumble out. It was the only AVS I ever saw that did that.
Chuck Beach is the guy to talk to about AVS's.
When you get one right it will work great.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
